This command displays current memory utilization of the MSDP process, including all virtual router instances of the MSDP process.
| detail | Displays detailed statistics for all memory types. |
| memoryType | Displays statistics for a particular memory type. |
N/A.
Use this command to view and diagnose the memory utilization of the MSDP process.
The following displays current memory utilization of the MSDP process, including all virtual router instances of the MSDP process:
show msdp memory
The following is sample output from this command:
MSDP Memory Information ----------------------- Bytes Allocated: 79792 AllocFailed: 0 OversizeAlloc: 0 Current Memory Utilization Level: GREEN Memory Utilization Statistics ----------------------------- Size 16 32 48 64 80 96 128 256 1024 4096 8192 12288 --------- ----- ------ ------ ------ ------ ------ ------ ------ ------ ------ ------ ------ Used Blocks 0 0 256 263 3 0 2 0 1 0 0 4 peer 0 0 0 0 0 0 0 0 0 0 0 4 mesh-group 0 0 0 3 0 0 0 0 0 0 0 0 sa-node 0 0 0 255 0 0 0 0 0 0 0 0 sa-entry 0 0 255 0 0 0 0 0 0 0 0 0 vr-node 0 0 0 0 0 0 0 0 1 0 0 0 rt-cache 0 0 0 5 0 0 0 0 0 0 0 0 rp-node 0 0 1 0 0 0 0 0 0 0 0 0 client 0 0 0 0 0 0 2 0 0 0 0 0 misc 0 0 0 0 3 0 0 0 0 0 0 0
This command was first available in ExtremeXOS 12.0.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the MSDP feature, see the Switch Engine v33.1.1 Licensing Guide document.
